Threads: 43
Thanks Received: 412 in 369 posts
Thanks Given: 137
33
21-11-2018, 01:45 PM
(This post was last modified: 21-11-2018, 01:46 PM by brodfather11.)
I've a 2001 berlingo but the wiper speeds are OK , yours has maybe had a harder life than mine regarding rainy weather
There is not much you can do to the linkages except spray with wd40 stuff. It could be the motor on its last legs ( 18/19 years old ?) a scrappy would be a cheap replacement if needed , that's where I got some linkages after they came apart at the joints
the wiper spindles on mine were tight in their housing so maybe worth checking on yours
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 8
Thanks Given: 305
36
Hi,
It's often the spindles that the wiper arms fix to that are corroded in the sleeves.
If you can get to the crank part of the rack that connects to the motor take that off from the motor and move the rack by hand, if it's stiff it will probably be the spindles.
The spindles come out of the sleeves, there's normally a cir- clip holding them, clean the spindles and the sleeves and lubricate with silicone grease, you can also add a dab of grease to the balls & sockets on the linkage.
If the rack is nice and free with no stiffness maybe the motor is starting to seize, maybe a worn out bearing or bush.
The following 2 users say Thank You to jj9 for this post:2 users say Thank You to jj9 for this post
• ron, rublehousen
Threads: 8
Thanks Given: 305
36
Absolutely
Threads: 8
Thanks Received: 7 in 7 posts
Thanks Given: 22
linkages not too bad, but were significantly improved with WD40, so ive oiled my balls and greased the shafts. only took about 40 mins.
refitted to van but still a bit slow. seem better with higher engine revs. alternator is ok. im thinking motor wiring, earth in particular could be poor connection.
next stop is to check multiplug for corrosion etc.
at least ive eliminated linkages as the fault
Threads: 9
Thanks Given: 316
15
I would say the motor seen it many times.
• rublehousen
Threads: 8
Thanks Given: 22
ive fixed it. took the motor off and removed clip on plastic cover. inside there is a brass contact that earths out on body of motor. like a prong that sticks up in a watch battery type affair.
there was a black build up on the brass contact and body (poor earthing) so cleaned it off and wipers now at full speed.
if fault returns i will put additional earth wire from pin 1 of the multiplug directly onto the alloy body of the motor as this contact inside seems a bit of a poor idea.
