22-11-2018, 11:40 PM
Hi All,
Noticed that the coolant is at the min mark. I managed to trace the leak to the "Radiator drain plug" or bleeding screw cap. This is a black cap, like a bike tyre cap on top of the coolant thermostat. See pdf (PARTNER VP (M59) - M59F 1 13E40B - DURITE HOSE COOLING.pdf), item N: 3. The screw is positioned on the very top of the thermostat housing (PARTNER VP (M59) - M59F 1 13E86B - OUTLET TANK SWITCH PROBE.pdf)
It is slowly dripping, I tried to screw it, but it does not want to move and it seems that is leaking where the cap/screw connects to the hose. I also tried to push it, but it does not really want to move at all, maybe should have tried with more force.
Has anyone seen something like this? I could not find this screw anywhere and most thermostat housings are sold without the screw, so not too sure what to do with this one. If I remove it completely without draining the coolant, I suspect quite a bit of coolant will leak.
Car is Peugeot Partner 1.6HDi (9HXC engine; 92bhp; 2007; M59), a badge difference to the berlingo. I know that the gasket leaks on these with age, but it is not the gasket this time.
Any help is more than appreciated.
Cheers,
saskak
PARTNER VP (M59) - M59F 1 13E40B - DURITE HOSE COOLING.pdf (Size: 143.98 KB / Downloads: 27)
PARTNER VP (M59) - M59F 1 13E86B - OUTLET TANK SWITCH PROBE.pdf (Size: 50.83 KB / Downloads: 12)
Cheers,
saskak
