Threads: 2
Thanks Received: 1 in 1 posts
Thanks Given: 2
Hello everyone. I've just purchased a 2004 Berlingo based camper van and the plastic sump guard is now dragging on the ground at the back of the engine. I've lifted it back to the position it should be in but can see no mounting holes where bolts might have gone through to secure it to whatever it should secure to. Has anyone had the same problem and solved it?
Thanks.
Threads: 7
Thanks Received: 42 in 35 posts
I've not looked under an M59, but a lot of other Citroens the back of the under tray just hooks onto the subframe.
A lot of the time the fixings where they attach to the wheel arch liners at the side tear the plastic. You can fix them back on with cable ties, it'll probably be stronger than it was before.
Threads: 2
Thanks Given: 2
Thanks Hawaiianblue, it didn't occur to me that the fixings might have been at the side rather than the back. I'll be back under there again tomorrow, weather permitting!
Threads: 9
Thanks Given: 316
15
There should be a stud that a hole in the undertray goes over and a nut is screwed onto. This secures the rear of the tray.
there are two more at the front + two plastic twist clips either side at the front.
Threads: 7
you can probably find a genuine metal sump guard from an xtr in a breakers.
