Threads: 4
Thanks Given: 2
Has anyone here repaired a sill on a Berlingo?
I'm about to start cutting and welding up the offside sill which has rotted due to a blocked drain hole and the last owner not using the jacking point!
Repair looks reasonably easy, just wondered if anyone has any photos of similar work they've done.
Thanks!
Sent from my SM-G850F using Tapatalk
Threads: 29
Thanks Received: 375 in 329 posts
Thanks Given: 67
20
28-11-2018, 09:04 AM
(This post was last modified: 28-11-2018, 09:05 AM by ffrenchie.)
I've done plenty of sills on different cars but never seen a Berlingo with rot. Look on
mig welding forum for inspiration there will be something similar to your job. Just make sure to cut out all the rot back to good metal before you start making a template for your repair piece unless you are replacing the whole section with a purchased panel. Anything you cut out should be seam welded if it is an insert but the bottom flange can be plug (button) welded for appearance to look standard.
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
28-11-2018, 09:51 AM
(This post was last modified: 28-11-2018, 09:52 AM by polar.)
Like ffrenchie ive never seen a Berlingo with a rotten sill may be it was damaged at some time an the corrosion set in?
Maybe the Citroen forum may help on this one? have you done a search?
Threads: 65
Thanks Received: 715 in 612 posts
Thanks Given: 225
50
At least with a Berlingo you won't get rot spreading ......
Many years ago my son came home with a Metro car and asked if I could put a new sill on it for him, to cut a long story short I ended up putting in two full sill panels, three quarters of a door pillar and used most of an 8x4 foot sheet of steel making a new floor and patching other bits !!!
Once you've done your repairs make sure you flood the internals with something like Dinitrol for lasting protection ( like waxoyl but better ) and you'll not have the pleasure of doing it all again in a couple of short years.
Serieal Berlingo owner
Threads: 29
Thanks Given: 67
20
No galvanised sections on the old Berlingo and no need to worry too much even if there are unless you have your head in a bag with the weld. Fumes will dissipate if you are in an open area big enough to house the vehicle.
