Threads: 4
Thanks Received: 3 in 2 posts
Thanks Given: 9
I had a puncture yesterday: 20 min before rescue service answered phone; 2 hours for the patrol to show up only to be told they could do nothing, the alternatives being an emergency tyre fitter who would charge an arm and half a leg or another indeterminate wait for a tow truck to be relayed 20 miles home.. At this point I had had enough and called the wife who came out to pick me up with the punctured wheel and we returned this morning after having a new tyre fitted.
Why? Our Berlingo Multiplas is a wheelchair accessible conversion with no spare because the rear floor is lowered. To be fair this was not a problem when it was a Motability vehicle as tyre maintenance and (priority for a disabled driver) rescue is all part of the contract.
However I do not want to be caught out again; the normal spare wheel stowage is not available so I am thinking of a skinny space saver wheel secure vertically to the inside. Has anyone recommendations for a suitable wheel or alternative ideas? (I am not keen on the can of sealant and electric pump idea!)
2014 Berlingo Multiplas 1.6 HDI, wheel chair adapted by GM Coachworks Group.
Threads: 7
Thanks Received: 42 in 35 posts
I expect you can use a space saver wheel from a Peugeot 206.
Failing that you can fit roof bars and put a normal spare on the roof, It would have a fuel penalty though.
Thanks Given: 188
23
Ive got an old 2008 M59 berlingo that was converted from new into a WAV. Its a gowerings conversion they are one of the biggest converter in the country and I have a spare wheel mounted vertically behind the single rear seat on the nearside wall. It has a big bolt fixed to the side frame the wheel is stood there and then a spinner is wound on to lock it in place, even has a nice cover over it. The jack and brace is in the usual place behind the panel on the other side. If room is tight as said above find a spacesaver that will fit and find a way to fix it vertical inside.
Are we there yet?????
• KeithPet
Threads: 4
Thanks Given: 9
(28-11-2018, 10:43 PM)hawaiianblue Wrote: I expect you can use a space saver wheel from a Peugeot 206.
Thanks hawaiianblue. I will follow up the 206 idea but I dare not put anything on the roof as I get enough hassle from Brittany Ferries, who are convinced I exceed their max height for normal cars rules, as it is!
Threads: 4
Thanks Given: 9
(29-11-2018, 07:41 AM)Tomcat3 Wrote: Ive got an old 2008 M59 berlingo that was converted from new into a WAV. Its a gowerings conversion they are one of the biggest converter in the country and I have a spare wheel mounted vertically behind the single rear seat on the nearside wall. It has a big bolt fixed to the side frame the wheel is stood there and then a spinner is wound on to lock it in place, even has a nice cover over it. The jack and brace is in the usual place behind the panel on the other side. If room is tight as said above find a spacesaver that will fit and find a way to fix it vertical inside.
Thanks Tomcat3. Mine is a GM Coachwork conversion. I have what I think is the original single folding seat behind the driver. I will investigate the nearside and try and find a fixing behind the trim.
