Engine tapping
Hi all
Got in my Berlingo van (09) yesterday and noticed the engine has started tapping not done this before checked oil level ok engine has done 57k now any ideas
For some reason your post duplicated itself so I deleted the dupe. Which motor do you have - petrol or diesel??
(01-12-2018, 11:10 AM)3rensho Wrote:  For some reason your post duplicated itself so I deleted the dupe.  Which motor do you have - petrol or diesel??
Diesel
(01-12-2018, 10:49 AM)wilky Wrote:  Hi all
Is it when it's cold..?
1.6. 1.9 or 2.0.
called Brian... Smile
1.6. 1.9 or 2.0.
1.6. 1.9 or 2.0.
Warm or cold same noise it’s the 1.6 hdi 75
Berlingo van 2009 diesel 1.6
1.6. 1.9 or 2.0.
You could use a large screwdriver or piece of wood ..
as a stethoscope,to pinpoint an area the noise is coming from.. Wink
1.6. 1.9 or 2.0.
I had the same problem with mine (59 1.6hdi 90). Eventually I had to have the injector seals replaced and the tapping stopped.
You could of course just turn the radio up!  Smile
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
Welding precautions
24-11-2025 12:37 PM
driveshaft tripod joint spring
24-11-2025 12:31 PM
