Sos noise
Hello guys, i have a berlingo 2009 plate and whenever im driving every 2 minutes, it speaks out ' press and hold button for 2 seconds to call the emergancy services ' i dont have a sos button and its so annoying. When i tap on the breaks it stops and repeats again. Usually happens when breaking as well. Anyone had this problem ??? Thanks
Sounds like it once had a telematics unit fitted and someone has removed some of it and the remaining parts have gone haywire. The telematics on some vans often looks like a satnav on the dash, some people remove the head when the sell the van not realising it's actually just part of a larger system.
You can either trace the main module under the dash and remove it or you may get away with just telling the BSI it's no longer there with a diagbox.
[-] The following 1 user says Thank You to hawaiianblue for this post:
  • WaqasAli1
Thanks but when i went to a Citroen specialist they plugged it in and its already deactivated on the BSI its never had a telematic in the van, they said change the break switch because when they was speaking to the engine through the machine the noise would appear when touching the break peddal.. i done that but its still happening..
Sent from my SM-G960F using Tapatalk
Where does the 'voice' come from? The Stereo speakers or somewhere else in the dash?
Basically the car think's you've crashed so it's trying to call the emergency services, however it can only do this if it has some kind of telematic unit in it, the BSI etc doesn't have the ability to do it on it's own.
  • WaqasAli1
The speakers i would say! Okay thanks well i dont kno what to do pretty annoying driving my van now every 2 minutes going off. Even Citroen specialist couldnt find the problem.. So what to do next?
What happens if you pull the stereo out and unplug it? Does it stop making the SOS noise?
I will try that tonight and get back to you, isit easy pulling the stereo out? Mine has got a on board screen.
A screen on the actual stereo or do you mean the separate one on top of the dash? (I assume you don't have satnav)
Seperate on the top, no i dont 2009 module
Stressful no one can find the problem!
Bumper with led
Last Post: Lingo09
Today 05:54 PM
Amdro boot jump for sale
Last Post: Jaybee
Today 04:41 PM
Paint advice
Last Post: Andhall
Today 02:35 PM
Should I buy this van?
Last Post: Duggie12
Yesterday 09:27 PM
sliding door panel removal
Last Post: mojito
Yesterday 07:13 PM
Twin Cam Chain Snapped need some Parts Advice
Last Post: kingy1912
Yesterday 01:10 PM
Rumbling Noise 55-65mph
Yesterday 01:06 PM
XL tyres
Yesterday 01:03 PM
Last Post: deejay_xb
23-03-2025 10:06 AM
» Replies: 32
Unusual Braking Problem
23-03-2025 07:57 AM
