Driver's window not working
My driver's side window decided to stop working, am not exactly sure when but it was fine the last time I used it a few days ago. Pressing the button has no effect at all, the passenger side is still ok. Has anyone seen this problem before, maybe there's a fuse just for that side.
Any thoughts welcome.
Cant remember how they are fused so you need to check all fuses.
The wiring can break in the conduit from the a post to the door so check for power at the motor.
My enigmatic or is that enigmatique window started working again last night. I can now hear a relay in the BSI clicking when I press the button which I couldn't hear in the morning. It was a bit cold when I set off, so maybe there was some ice stopping the window. Maybe it thawed out during the day, but I resisted the temptation to try it on the M62 just in case it only worked one way. In the evening I tried it so that I could pay for diesel at ASDA without getting out of the car.
Yesterday evening the window went down when I paid for fuel at ASDA, then declined to go up again a couple of minutes later. I turned the ignition off, then turned the key back to 'aux' & the window went back up when I pressed the switch. After that I started the engine and drove off, while driving I tried the up switch a few times and could hear the relay in the BSI clicking which I couldn't hear before, so I'm guessing there's a dry or loose joint somewhere?
I'll take a look at the wiring diagram today but thought I'd ask if there are any thoughts?
A quick update and a request for some help.
Both windows are now working 100% fine....
I've attached 2 files showing the wiring for the windows, they are quite different from the looks of things. Both are AFAIK for the M59 but the version (2) is for a later RPO, mine as it happens.
Please can anyone try the window 'up' switches while the windows are closed and let me know what year your car is & if there's a relay 'click' from the region of the BSI? Mine only clicks when I try the driver's window.
It may be because the drivers side has the 'one touch' feature although that only works going down.
TIA
.pdf   Window(1).pdf (Size: 806.4 KB / Downloads: 12)
.pdf   Window(2).pdf (Size: 1.23 MB / Downloads: 9)
Just went out to try this as feel I owe you a few favours for your help on this forum. However, had forgotten that my poverty spec car has manual winders! D'oh!
(25-01-2019, 03:05 PM)mikeyr Wrote:  Just went out to try this as feel I owe you a few favours for your help on this forum. However, had forgotten that my poverty spec car has manual winders! D'oh!
Oops! For the amount of times that I open & close my windows, a couple of manual winders might have been a better option.
(25-01-2019, 01:27 PM)cancunia Wrote:  . . . Please can anyone try the window 'up' switches while the windows are closed and let me know what year your car is & if there's a relay 'click' from the region of the BSI? Mine only clicks when I try the driver's window.
TIA
Mine makes the same click from the BSI on the driver's window.
I believe the one touch feature only works when the window is going down.
https://www.berlingoforum.com/thread-16082.html
  • cancunia
(25-01-2019, 01:27 PM)cancunia Wrote:  Please can anyone try the window 'up' switches while the windows are closed and let me know what year your car is & if there's a relay 'click' from the region of the BSI? Mine only clicks when I try the driver's window.
TIA
Bump!
Today 11:13 AM
Today 09:14 AM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
