RPM Sensor connection.
Hello to everyone
as i said in the other post i have a 99' Berlingo .
i'm fixing it becouse the past owner had the bad attitude to take out everythings not working.
the RPM cluster is completely dead.
i found on google that can be the sensor
i checked al the engine and i can't see the sensor,i think it was removed completely.
There is just an hole on the gearbox on the border close the engine,can be the hole of this sensor?
if yes where then i must connect,i can't see any plug
if someone have a picture i will be really happy!
thanks so much!
Attached Files Thumbnail(s)
nobody know?
hi ,
If I recall there were two positions for the crankshaft sensor either at the crankshaft or in that hole you are refering to .
The speed sensor is the speedo drive which is (I think ) the white socket just to the right and below the hole you circled. On the CATcar site it sits in the Tachocontrol housing  so it must do both jobs, speedo and tacho. ( rev counter).
 Someone else may know more
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
