key fob????
i have a keys fob with lock/unlock buttons.
am i correct in thinking my 2006 600d X spec never had central locking or is it currently not working?
If it's a van you never know. A lot of them are bought by fleets who order all sorts of odd specifications to meet their needs - if you order enough of them you can pretty much have anything you like even bespoke colours.
Check to see if there is a fuse for Central locking fitted and if it's there, is it blown.
\Another option is to Pop the interior trim off the back door and see if it has a central locking servo on the lock mech. (back door trims are much easier to remove than the front doors.)
cheers mate il pull the trim off tomorrow morning.
getting piss tired of her complaining at me because i get in the van then have to lean across and let her in, especially with the weather incoming over the next few months
do you have a lock button on the centre console? if so, then you probably do.
I recently fitted a cheap aftermarket remote system as my key-fob was kaput. pretty simple, and only cost about £8.
Tapped the harness going into the fuse box for a constant live (and a switched for my stereo) ran a wire above driver foot well to behind where stereo is, removed clock cover/stereo/and all facias - probed the lock switch on dash and took note of voltage behaviour during lock/unlock/power save, and then set up the aftermarket unit to inject 12v when key fob is pressed. unit sits nicely behind the stereo.
2005 Berlingo Multispace Desire 2.0hdi
Today 03:10 PM
Yesterday 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
Last Post: stu76
18-08-2026 07:16 PM
