Undoing oil sump bolts.?
hi guys
now removing sump bolts is usually a simple task,
but these are so tight the Allen sockets are turning in the bolts,
surely these bolts are no usually so tight...
any suggestions ?
called Brian... Smile
Are the bolts now rounded ?
Gentle persuasion using an impact driver with an Allen bit perhaps. Maybe some heat on the bolt heads.
(07-12-2018, 03:37 PM)geoff Wrote:  Are the bolts now rounded ?
no.. but I can feel the bit moving without the bit turning..
so its getting close .. Dodgy
(07-12-2018, 04:52 PM)cancunia Wrote:  Gentle persuasion using an impact driver with an Allen bit perhaps. Maybe some heat on the bolt heads.
I don't have an impact driver.. Confused
I have a blow lamp... Shy
theres a bloody lot of bolts... Angry
i always hammer a torx (stardrive) bit in
Get the allen bit in the bolt and give it a bang with a hammer to shock it - if not heat and a bang with the hammer.
  • Art b
(07-12-2018, 06:23 PM)frank Wrote:  i always hammer a torx (stardrive) bit in
Yup... I can see it coming to this... Big Grin
(07-12-2018, 08:31 PM)polar Wrote:  Get the allen bit in the bolt and give it a bang with a hammer to shock it - if not heat and a bang with the hammer.
I had a little go like that , no joy.. Rolleyes
I recently had to replace a corroded sump. Ireplaced it with an alloy sump and had to buy new longer bolts. They cost more than the sump. M7 an odd French automotive size. I undid the old ones by giving the Allen key bit a sharp tap to make sure it was started properly and to shock them.
I now have a spare set of used sump bolts for a steel sump.
Peter
[-] The following 1 user says Thank You to Romahomepete for this post:
  • Art b
Leaking windscreen or aerial
15-04-2026 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
