Door light switch - HELP!!!
Hey folks!
Does anyone knows how to connect the door light switch? My dome light is working. It also turns on when I open the trunk door but not when I open the front doors. The switch has two metal pieces but the connector only has one entry.
Is also any other way to troubleshoot this problem? What else can I test to see what's wrong with the door / dome light?
Also does anyone knows where those door light switches are connected to? fusebox?
Please would appreciate any help asap! Sad
Door light switches are often wired so the single wire connects to ground / earth when the door is opened. You can test this by putting a 12v bulb in series between the single wire going to the switch & a known good earth. If both bulbs light, you will know where your problem is.
There is an M59 handbook in the top of that section of the forum, but I doubt if the fuses are the same. There's also a Haynes manual somewhere on the forum, a search should find it.
Leaking windscreen or aerial
15-04-2026 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
