Headlights staying on
Hi. after driving home with headlights on, sometimes not every time, i turn off lights and then turn off engine. as i get out of van the headlights come on and stay on for approx 1 minute or so.
is this a courtesy feature? or is this the impeccable french electrics developing some character?
can i turn it off if its a feature?
is this a known electrical fault or the start of something much bigger? hahahahaha
cheers
Rob
Berlingo Multispace Forte, 2001, 1.9D, DW8B, WJY,...with a smashing green and yellow interior.
On the M49 I would probably say it's a gremlin Big Grin Check your light switch for play or loose connections would be my first option.
  • rublehousen
I think there's a feature on some models to do what you've described. IIRC you activate it by pulling or pushing one of the steering wheel stalks. I've not tried it myself so am only thinking out loud from a distant memory. Maybe the infamous BSI reset would help, plenty of details via a search.
  • rublehousen
I remember reading in the B9 literature about a feature that I believe was/is called "follow me home" or some such wording. I've never seen it but that sounds like what it might be. But as ffrenchie says, on an M49 it is probably a bug.
[-] The following 1 user says Thank You to 3rensho for this post:
  • rublehousen
oh i just remembered, the heater fan did not work the other day...turned it off and back on and its been fine since. looking more like a gremlin....
Check your BSI for damp.
Plenty of posts on that subject on here.
  • rublehousen
(14-12-2018, 12:17 PM)cancunia Wrote:  Check your BSI for damp.
cheers, where do i locate this infamous BSI?
im assuming its a module of some sort maybe in front footwell from the posts ive read?
is it a water in the multiplug affair?
i remember drying rover ecu's out on radiators many moons ago...
cheers
i think its actually a 'courtesy light' feature now. if i turn lights off after the ignition they stay on for a minute(ish), if i turn them off before the ignition they stay off.
bashing the dashboard to get the fuel gauge working and R/H dash speaker is clearly another matter.....?
[-] The following 1 user says Thank You to rublehousen for this post:
  • cancunia
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
