Fascia fuses - heater fan stopped
Berlingo March 2009 M-SP XTR diesel
Just bought this and the heater fan has stopped working from all positions of the switch.  Thought I would start by checking the fuse but removing the cover on the passenger side fascia reveals several clusters of wires obscuring the fuses behind them.  How do I get at the fuses and also there is no indication in the manual to the heater fan fuse no.  There is a fuse for the aircon and wing mirror but the aircon light comes on and the wing mirror movement works so I assume its not that.
(16-12-2018, 09:55 AM)ronhud Wrote:  Berlingo March 2009 M-SP XTR diesel
This is probably the dreaded resistor failure, a real PITA to get at and change.
Although they usually still work of "4"
https://www.berlingoforum.com/thread-164...hlight=fan
Yeah, as above, the highest setting does not normally use the resistor pack and goes direct to the motor. Not 100% sure if this is the case on a B9 tho.
Last Post: jw4821
Today 11:25 AM
Last Post: JPCoetzee
Today 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
