17-12-2018, 10:15 AM
So I'm set to wire in a leisure battery, it'll fit just under the passenger seat. Got the split charge kit. However I'm a little unsure what gauge wire to use from the battery to the fuses. The only thing I'll be running is a all in one deisel heater and maybe a couple lights. The heater will draw around 20amps on start up.
What gauge wire would you recommend for battery to fuse box?
Thanks.
Thanks.
