tensioner pulley
Threads: 11
Thanks Received: 5 in 5 posts
Thanks Given: 82
Following on from my last question, I'm thinking about replacing the other pulleys, the pulley on the tensioner just looks like it's bolted on, is it OK to just replace the pulley, or should I go for a new tensioner assembly?
Thanks again.
Threads: 123
Thanks Given: 250
34
The tensioner pulley comes as part of the tensioner assembly from Citroen, but there are sellers on ebay just selling the pulley if you search on the part number. I did a fair bit of investigation a few weeks ago but decided to leave things alone until the weather gets a bit warmer. The part number will be on the catcar page, put that into ebay.
Threads: 11
Thanks Given: 82
Thanks again, you don't see a problem just replacing the pulley, rather than the whole tensioner?
Threads: 123
Thanks Given: 250
34
18-12-2018, 04:31 PM
(This post was last modified: 18-12-2018, 04:34 PM by cancunia.)
TBH, I don't know the answer. The belt tension is released by turning the bolt that holds the pulley clockwise so it's probably quite tight but beyond that, it's a bolt holding a pulley much the same as the idler, probably a bit of threadlock would help. The main difference is the price so far as I can see.
On some models, it's shown separately and is the same bolt as the idler roller.
https://www.catcar.info/citroen/?lang=en...I9PQ%3D%3D
Threads: 11
Thanks Given: 82
That's what I was thinking, I'll add it to the list of jobs to do, thanks again.
Threads: 123
Thanks Given: 250
34
(18-12-2018, 05:15 PM)RJBingham Wrote: That's what I was thinking, I'll add it to the list of jobs to do, thanks again.
Post how you get on? I need to add it to my list.
Threads: 15
Thanks Received: 102 in 92 posts
Thanks Given: 15
6
Hi -did both on ours last year - one of them was 'whizzy' after some very wet weather, I couldn't work out which it was, so just got two and swapped them out - no problem with the tensioner one other than securing the tensioner with something thin & non bendy so that there was no excess leverage on the spring.
Did the same at the same time to the Renault but used cr*ppy pulleys (Berlingo got Gates) and one of the cheap ones died after only a few thousand miles and lost the V belt (buy cheap buy twice as the missus tells me)
Threads: 24
Thanks Received: 39 in 35 posts
Thanks Given: 487
(18-12-2018, 07:00 PM)GraemeT Wrote: Hi -did both on ours last year - one of them was 'whizzy' after some very wet weather, I couldn't work out which it was, so just got two and swapped them out - no problem with the tensioner one other than securing the tensioner with something thin & non bendy so that there was no excess leverage on the spring.
There are a lot of cheap parts out there..for every thing,
It shows why some stuff is just not built to last..
called Brian...
The following 1 user says Thank You to Art b for this post:1 user says Thank You to Art b for this post
• RJBingham
Threads: 123
Thanks Given: 250
34
The noise from my 1.6D aux belt is beginning to get to me so I decided to buy some new pulleys. The idler pulley seems easy enough to find, but I'm having difficulty tracking down the pulley that goes on the tensioner. There are plenty of complete tensioner kits, but the roller on it's own is a bit elusive.
If anyone has bought a tensioner roller and has a link, part or item number, please can they share it?
TIA
Threads: 8
Thanks Given: 305
36
Leaking windscreen or aerial
15-04-2026 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
