Threads: 3
I have a 2003 multispace and the stereo lights stay on even after ignition switched off which i think drains the battery after a few days,any ideas on solving the problem.
cheers
Threads: 123
Thanks Given: 250
34
26-12-2018, 02:26 PM
(This post was last modified: 26-12-2018, 02:30 PM by cancunia.)
Search on here for the BSI reset, also maybe let the car stand with the bonnet propped open, doors closed & without the key in for about 30 mins to be sure the car has fully shut down, then disconnect the battery for another 30?
Threads: 28
Thanks Given: 78
If it's a after market radio , the permanent live and the key live wires could be swapped around causing this sort of problem.
If this is the case and you have the ability you could swap them, if you don't like wireing you can get a autoleads or connects2 adapter harness that swaps them for you.
Mark
Threads: 3
no its the standard radio fitted. i will try look for a wiring diagram to see where the permenent live is supposed to go
Threads: 3
still original wiring, there used to be a hands free phone fitted, i have removed all the remains of that, i will check the permenant live to se if its going to correct pin on stereo...it does say peugeot on stereo not citroen
