Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
01-12-2011, 12:54 PM
(This post was last modified: 01-12-2011, 10:56 PM by taxi.)
Just noticed a deep crease appeared in one of my rear seat bases after only seven weeks, seems that the foam on that seat is incorrect size and causing a crease/fold where it joins the bolstered piece.-will have to contact Citroen to replace or repair,I suppose-Has anyone had this problem ? And if so, was it fixed by Citroen ?
Former 2011 Mk3 XTR owner
alut:
Threads: 96
Thanks Given: 709
Seat returned to original shape after wet vacuum- result.
alut:
The following 1 user says Thank You to taxi for this post:1 user says Thank You to taxi for this post
• XTR
