I open this thread due to a simple repair witch i hope that helps you.
On my partner 1.6hdi the air pipe was always losen i put tape and bracelet how ever i did another solution.
So i drill two holes, one on each edge of the 1st section pipe and then i hold with thread plastic rivets it was a better solution as you can see in the pictures.
I thougt in put normal metalic rivets but i was afraid of damaging the pipe.
Step by step:
1-take out the pipe;
2- use drill bit n 4 until n6 iuse the rivets with 6mm;
3- install the pipe
I hope that it helps you bevause i already get a lot of from this forum
Step by step:
3- install the pipe
is very useful.
