[Engine] Help! Engine suddenly not turning over.
Hello, I' looking for some help l. My 09 1.6hdi Berlingo was running perfectly started 4 times same day no problem, I let someone else borrow it and they went about 10 minutes away stopped the car and a few minutes later returned to a van that wouldn't start. Key turned in the ignition and lights up beeps as normal however will not turn over at all. All other electronics are working ok. I spoke to a garage locally who suggested it was an issue with the key so I got onto a specialist who insists it doesent sound like the key. According to him as well it's not the immobilizer because it would still turn in that case. I tried jump starting as well no difference there is plenty of power in the battery.
So to summarise it makes no click or turn or any noise at all that I can notice when the ignition is turned so any suggestions? I'll try anything at this point,
Thank you
you need to do some diagnosis with a volt meter really seancie, to check the feed to the starter motor
Thanks for the reply Frank, the van is a few miles from my house so I'll have a look later. I found a post on another forum that seemed like a similar issue and it turned out to be a fault with corrosion on an earth wire, any thoughts on this possibility?
Sean
possible mate, i bought mine with a duff starter tho, a right mission to get to they are !
Well I'm hoping it's not a starter problem as it always started first turn and never laboured but who knows really
If you suspect the main earth cable use a jump lead from the Negative of the battery to any metal point on the engine as a test.
The starter motor is well tucked away at the back and difficult to get at. I know the connections on mine were a bit furry with corrosion so I wouldn't rule it out.
Can you not bump start the van  to get it home?
haven't bump started her yet as shes on a busy street unfortunately, silly question time is there any reason it wouldn't bump start?
If electronically everything is working and the problem is just the starter motor it should bump start ok.
There is a fuse for the starter in the underbonnet fuse box .
(05-01-2019, 04:50 PM)Lighty Wrote:  There is a fuse for the starter in the underbonnet fuse box .
And it’s very common to blow at the most stupid times as mark says, generally due to a sticky solenoid not being able to throw the motor, this then takes more current and generally messes up the job
I will add that just because it starts the engine with ease and great speed it doesn’t mean that every part of the starter is ok, it’s very possible that the inertia part of the starter has become tired and the first thing you will notice is the fuse blowing as the current creeps up required to throw the motor to engagement
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
