Radio Signal Diagnosis
The radio on my new to me Berlingo 2002 didn't work, the CD did..
I pulled the unit (see head unit manufacturers instructions) and removed the aeriel plug. It's the single 6mm black lead. You will see that in the back of the unit there is now a 6mm hole at the bottom of which is a 1.5mm hole for the pin on the plug you just removed. Stick a bit of insulated wire down that hole and hang it out of the window. The radio will now work. If it doesn't then this won't help
You have now diagnosed that the fault lies with the aeriel. Assuming the aeriel on the roof is secure and in good condition it is likely that the connector for the aeriel lead at the head unit end is broken. Cut it off and fit a new one. The part you need is
Aerial Antenna Male Plug DIN 41585
You will need to solder it for best results. Plenty of vids out there on that. Good luck hope this helps somebody.
Sent from my COL-L29 using Tapatalk
[-] The following 2 users say Thank You to benrums0n for this post:
  • cancunia, CherryBomb
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
