11-01-2019, 06:45 PM
So ages ago I purchased a lowering spring set from FK in Germany for under 30 quid delivered...
So for whatever reason I never fitted it to my 09 partner...
Fast forward to today and my new van has arrived...
A 90bhp partner with 31k on the clock, it’s ex police and has had 10 services in 5 years from new
It’s also not been thrashed as I know it’s history and what it was used for (classified)
So I just fitted the springs in 2.5hrs single handed while giving the van a once over too
Now I took some measurements of before and after... I can’t recall if my new 307 17’s were in the back on initial standard measurements
So measurements as standard / after / drop (all to highest point of arch above wheel centre)
FL 718 / 686 -32mm
FR 718 / 685 -33mm
RL 741 / 705 -36mm
RR 737 / 706 -31mm
Oddly it has squared the van up a little... I will give it a bit of time driving it before deciding whether to remove another coil from the rear and lower it a fraction more (maybe 10mm I reckon as the last coils are progressive and are parallel and the same angle for the first four coils... in theory you could cut two or more extra off and lower it to the floor but the front would be a bit awkward as both ends are pigtailed slightly)
I will also take some pics when the wheels are added in... just waiting on 16 flat washer alloy wheel bolts to come then I can put em on ?
I reckon also 307 late suspension will also fit as the rear beam and struts look very similar from memory?? Possibles for coilovers I reckon ?
FL 718 / 686 -32mm
FR 718 / 685 -33mm
RL 741 / 705 -36mm
RR 737 / 706 -31mm
