Loose connectors under dash
Can anyone tell me what the loose brown conectors are by inside fuse box.
Attached Files Thumbnail(s)
For switches that are not fitted ?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(17-01-2019, 12:31 PM)Hooligan Wrote:  Can anyone tell me what the loose brown conectors are by inside fuse box.
Could u tell me what year your berlingo is. I have been looking 4 away to put wires in 4 the ambient temperature sensor. I think u might of found them
2003 Multispace Desire 1.9d
Like Brodfather says, probably for something that's not fitted. Is there anything not working?
For the outside temp, the sensor is in the mirror, probably driver's side for RHD. Wiring from the sensor goes to the BSI. Cars before sometime in 2004/5 do not have the wiring to the BSI, and maybe don't have the hardware/firmware in the BSI to translate the readings for the MFD.
There are quite a few threads on here about the outside temp.
hardware/firmware in the BSI to translate the readings for the MFD.There are quite a few threads on here about the outside temp.
Been in to the bsi and it says it's there. Got small dash display from peugeot 307 and it works. Just 2lines and a small c. Was trying to wire it in my self. But can't find and wire diagrams.
Have a read through the thread linked below, there are quite a few others that can be found with a search. If you're still looking for info, a new thread would probably be best.
https://www.berlingoforum.com/thread-4053.html
  • kingash
SOLVED: P20F6 fault
Today 08:28 AM
Coolant
Last Post: Martinze
Yesterday 08:24 PM
Leaking windscreen or aerial
15-04-2026 08:50 PM
