Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 8
19-01-2019, 10:56 AM
(This post was last modified: 19-01-2019, 10:57 AM by malgpz900.)
Anyone got any ideas.
2001 1.9D. DW8 engine I think.
Idle speed has always been around 1100 rpm when cold, drops to just below 1000 rpm when warm.
Any ideas how to lower it.
Did a search but all seem to be about petrol or later diesels.
Any suggestions appreciated.
NB. Never bothered me before in 5 years of ownership, but now it's running well though I might see if I can sort it.
Malcolm.
2001 1.9D Multispace.
Threads: 9
Thanks Given: 316
15
Think i remember about 650 but i may have made that up!
1100 is fast idle speed, may have a faulty wax stat or a split pipe from the solenoid.
Threads: 22
Thanks Given: 8
(19-01-2019, 05:10 PM)polar Wrote: Think i remember about 650 but i may have made that up!
Thanks for the reply. Need a bit more into please. By wax stat what is the correct name for it. Tried googling wax stat without success, and a bit more info please on split pipe from solenoid. Cheers.
Threads: 9
Thanks Given: 316
15
Its difficult to explain but the 1.9 has a fast idle device but it depends which one you have if you look for fast idle you may find some info. Some are operated by a cable off a wax stat others are off an air electric solenoid it just depends on yours - i suspect you have a solenoid type - if you get a split in the vacuum pipes or a pipe has come off it will stay in fast idle.
Stary by looking around the engine bay for split and adrift vacuum pipes.
