Threads: 10
Thanks Received: 2 in 1 posts
i want to fit a multispace headliner in my 06 van.
is it just a case of clipping the multispace liner in?
how difficult a job is it to fit?
cheers
Threads: 48
Thanks Given: 4
20
The biggest issue is the covers on the B pillars as that's where the seatbelts are anchored.
you need to be able to remove at least one of these to get the headliner into place.
(Remove panels on the A and B pillar on the same side, tuch the headliner into the top of the panels on the other side and lift it up, then pop the A pillar cover into place, and work your way back with mounts, bracketry and fasteners.
The biggest issue is that the liner is large and fragile. Ideally, you want to be two people to handle it at all times.
Threads: 10
thanks for the advice mate, going to pick one up this weekend and have a crack at it
