  • 7 Vote(s) - 3.43 Average
towing a caravan
Hi,
Does anyone know if the 1.6hdi 90bhp is powerful enough to tow a caravan with a weight of 1000kg ? I don't know if I should go for the more expensive 110bhp. Anyone got any experience of towing with the 90bhp model? Any advice greatly appreciated.
Hi there jjb,
i currently have a 2.0 HDI which is only 90 bhp and tow a caravan of around 1100kg mgw and it pulls it very well so with your van being less weight it should be ok, i know it is a smaller engine but has same power output just one thing i reccomend is to plan ahead with gear changes for example drop down a gear in enough time for going up hill etc.
hope this helps for now and maybe someone with the 1.6 maybe along shortly but in meanwhile try this website
whattowcar.com
on top left of page there is a link to outfit matching fill this in and should give you a rough idea
[-] The following 1 user says Thank You to BerlingoHDI for this post:
  • jjb
(03-12-2011, 02:10 PM)BerlingoHDI Wrote:  Hi there jjb,
whattowcar.com
Hi Berlingo HDI, Thanks for the info.Last thing I want is to buy something not suitable.Will check out your suggestion ,thanks again.
Just thought I'd let you know that I bought a 2009 Berlingo Multispace 1.6HDI 110bhp last week.I'm really pleased with it and feel I got a good deal and great service from Bentleys Citroen (Warrington) It's a Citroen approved car and comes with 12 month new car guarantee and 30 day exchange option if I'm not happy with anything.
All I need to do now is have a towbar fitted, hook up the caravan and hope for the best !!
Last Post: wbchevron
Today 07:34 AM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
