Speedo / Instrument Cluster Removal
I need to take the instrument cluster out on my M59. Am I correct in thinking that the cowling over the speedo etc is held on by clips and can be eased up / out?
(22-03-2019, 02:19 PM)cancunia Wrote:  I need to take the instrument cluster out on my M59. Am I correct in thinking that the cowling  over the speedo etc is held on by clips and can be eased up / out?
The top cowling slides out, it is only held by clips. Basically, pull towards you. It is not up, rather towards the driver. The speedo itself is more awkward and I initially thought it cannot be done. There is only one bolt holding it. Then the cluster is held by a clip behind the bolt. You have to push the plastic down to unclip it.  Then kind of pull towards you and up and it should come out.
EDIT: the cable at the back is short, so do not pull too much.
[-] The following 1 user says Thank You to saskak for this post:
  • cancunia
Thanks for the tip, I put a thin putty knife / paint scraper into the gap at the back and the cowling came forwards easily with a small amount of levering. In fact it was easier once I knew how, than getting the MFD out.
I've attached a picture that might help in case anyone's interested. There's a clip missing from mine, just like the picture.
Attached Files Thumbnail(s)
Today 04:31 PM
Today 11:13 AM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
