Threads: 3
Thanks Given: 2
Thank you I will pass that on to the tech who said he could not find the speed sensor
The car is on a 60 plate with the following faults , No power steering , No speedo reading , ABS light on. , Engine management light on , Battery light on
The tech thought he would try the speed sensor first
Threads: 123
Thanks Given: 250
34
I'd be tempted to try reading the fault codes first.
What model is your 2010 car?
Did they have electric power steering in 2010?
Threads: 7
Thanks Received: 61 in 55 posts
Thanks Given: 16
all these lights on, one should first test the voltage of the battery... It is very likely that that is the problem...
Threads: 3
Thanks Given: 2
Yes the car starts and runs apart from the bleeping and warning lights it runs fine
Lucky my mot is not due for 6 months , I should not drive it bacause of the faults but needs must , Lucky I have a works van for work
