05-04-2019, 01:56 PM
Hi all, my first post on here. Got an 05 Berlingo (AKA bike bus), into which I have fitted a cheap dash cam and reverse camera, all the wires cunningly routed through the modutop and powered by the constant 12v supply in one of the roof glove boxes. All works fine.
I want to be able to turn off the "always on" nature of these 12v sockets, by inserting a switch into the wiring for this circuit. I don't have Air Con, and have 2 blank dash buttons. So I bought an Aircon switch button (part number 9646088877), so that I can use it as a dumb switch. I chose the Air Con one as it's one I don't have, and it has the LED for when it's on, so I want it to light when the 12v supply is on, and I'll know it's off when it isn't.
The issue i have is one of finding out how on earth to wire up this switch, it has 5 terminals that would normally just connect via a block into the Air con system, and I have no idea which pin does what. I have used all my google-fu up trying to find the pinout or a wiring diagram that isn't a whole zircon schematic, and failed.
Can anyone assist?
Many thanks!
Dan
Can anyone assist?
Many thanks!
Dan
