Threads: 2
Have done a search but unsuccessful. All the Berlingos I have seen thus far have the antiquated H4 headlights. Are there any models that have say an H1/H7 combination or Xenon lights?
Threads: 9
Thanks Given: 316
15
Why does it matter? H4s are fitted, they work and are reliable.
Thanks Given: 188
23
Try some Osram nightbreaker bulbs in your headlights they make a vast difference. Not sure what fitment you have in the B9 versions but there will be a fitment for your car.
Are we there yet?????
Threads: 39
Thanks Given: 1
4
I use Osram nightbreakers and have done for years in our M59 based camper and now also in our B9 car and they make a fantastic difference
Threads: 0
Thanks Received: 2 in 2 posts
(07-04-2019, 06:26 AM)Tintim Wrote: Have done a search but unsuccessful. All the Berlingos I have seen thus far have the antiquated H4 headlights. Are there any models that have say an H1/H7 combination or Xenon lights?
Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
(07-04-2019, 09:59 PM)Tintim Wrote: (07-04-2019, 09:05 AM)polar Wrote: Why does it matter? H4s are fitted, they work and are reliable.
. . . I suggest you try driving a vehicle in welsh rain at midnight in late december that has xenon or twin H1/H7 and compare with the pathetic H4's. . .
Brighter headlights may be marketed and regarded by many as being safer in as much as they provide better visibility, initially this may appear to be a good thing, but on the type of roads you mention if you light the road better there will be a tendency to drive at increased speed.
Please resist any sort of super bright LED conversion, if you meet an oncoming vehicle with LED headlights on a dark country road you really can't see where you are going, even in the city where the streets are lit you are often blinded by the LED lights manufactures have taken to fitting to newer vehicles.
The problem of super bright lights has been recognised and a lot of drivers are realising they are causing problems.
https://www.rac.co.uk/drive/news/motorin...o-drivers/
Threads: 48
Thanks Given: 4
20
Note that as far as I know there's not a single LED conversion kit for H4 that's approved for road use. None of the 'bulbs' have the point lightsource required to fit the profile of the headlight lens.
Also, don't be tempted to fit stronger bulbs, even if you can find them for sale. They're meant for racing only. They will give beter light in the start, but after a while the much higher heat output will destroy the reflector in the back of the light. This isn't an issue for the racing circuit because there headlights are considered a 'consumable'
Stick with 'Nightbreakers' and possibly add an extra set of lights with different bulbs.
I have a set of H7 lights I plan to fit my M49 soon...
I also have a wiring kit I picked up at a local HW store that hooks in between the bulbs and sockets. It consists of hefty relays and thick wire. (They use the regular healdight connectors to drive the relays, which are coupled between the battery and the headlights. Shorter and thicker wire than the regular loop from the battery, to the relay under the dash, thin wire back into the engine compartment and the bulbs)
