12-04-2019, 06:03 PM
berlingo m59 2007
had a problem with water in bsi sent for repair to it was not repairable found used unit set away to clone came back not working they were very good and sent me a virgin unit
set it all up with lexia chinese clone all went well van started c/locking worked the only problem was the dash.
all lights on beeping no gauge movement mileage just a row of dashes and when turned of and key out dash stays on as do headlamps,
after 4 minutes you hear a click bsi sleeps and all lights out .
fault codes u0028 and p0c11 .
checked wiring canbus wires at bsm has 4.5volts and 2.5 v fluctuating so i presume cam bus is ok
id desperation striped can wires along the front looked ok but i spiced in new wires still the same.
thinking its still a bsi fault i purchased a bsi ,ecu,key kit from zantia all numbers on bsi same ecu model but slight different serial number
fitted it all on van started and ran but dash still the same
cleared all codes still the same
found a used dash fitted it still the same
i can access the instrument on the lexia and a launch and all work and test good
looking for wiring diagram for this vehicle as i only have access to autodata and the diagrams on that are not good
am i missing something ??? what can keep the bsi awake after turning off?
i have tried bsi reset many time
hazards do not work and heated rear window doesn't work but if i sit in the van and wair until it sleeps and then press the hazard dishe light up headlamp on but no hazzard
anybody come across this problem
the launch explanation of p0c11 is com fault with engine relay unit ecu
any help or advise welcome
