15-04-2019, 10:30 AM
Hello everyone, my 1st ever post so here goes. I have a 2003 (m59 I think) berlingo multispace 1.9D. I have had it since new and I love it.
A couple of weeks ago, while coming up a hill near home the car started chugging and died. The diesel gauge said 1/4 tank so didn't think it was fuel. As it turned out after getting picked up by a recovery truck and towed to a garage (the tech said it sounds and felt like no fuel) I put in £50 and after a bit of priming it started and all was good. Left it running at home on the drive for 1/2 hour. All good.
The next time I used the car was 5-6 days later, and when I started it there was a terrible screeching noise. I immediately turned it off and started it again, same noise so I revved the engine and it went away. Fan belt maybe I thought?. This happened on nearly every time I started the vehicle and a quick rev up and it went away.
Now this screeching/grinding noise is happening more often, it does it when driving sometimes. other times while on tickover. I'm disabled so bending over the engine bay is a problem at times. My son says the noise is coming from the right hand side of the engine bay (ie opposite the belts). But he could be wrong??
This has only started happening since I ran out of fuel. I have tried pumping the fuel primer a few times and MAYBE this helped make the noise go away but not too sure.
Any advice would be greatly appreciated. Thank you.
