Dw8 horrific sounds for miles then cleared !
Been away for a few days with the family in my non turbo diesel, after about 450 miles over 2 days all of a sudden there was a very loud rattle very similar to tapping tappets but worse or knocking bottom end etc ( sounded terminal).
This was on motorway slowing down didn't help and it was whenever I tried to put any load on motor. Decided to limp it home at 60 mph and try not to use accelerator and after 20 odd miles it just cleared! The car never lost power or smoked but I'm convinced it's engine related not box / drivetrain and to me sounded like I imagine an engine about to expire through lack of oil pressure etc sounds.
Been out today everything is normal
Sent from my Moto E (4) Plus using Tapatalk
I had similar about two months ago , shortly after fuelling .
To me it sounded like "pinking " like you get if the engine timing is out. Like you after twenty miles or so it was back to normal and never reoccurred .
On the 1.9d there is an advance and retard solenoid on the back of the HP pump it may have stuck temporarily and later freed itself.
It was as if it may have been caused by the diesel fuel having a little petrol or kerosene in it or ??????. Certainly couldn't smell any petrol in it
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(16-04-2019, 07:49 AM)brodfather11 Wrote:  I had similar about two months ago , shortly after fuelling .
Yeh sounded similar to pinking I've heard in older petrol cars but louder and faster reminded me off my old cvh with hydraulic tappets which would rattle similar on first start.
Fuel makes sense though as when I bought the car about 1500 miles ago it had quarter tank but since I've had it it's never dropped below half apart from said journey. Definitely sounded terminal
Also after servicing etc I'm still getting poor mpg so I'm gonna check the timing as previous owner had belt done
Engine Fan Running
Yesterday 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
Welding precautions
24-11-2025 12:37 PM
driveshaft tripod joint spring
24-11-2025 12:31 PM
