Washer motor queryt
Hi there - the washer motor on my berlingo XTR 2009 has gone.  The car is in France so planning on replacing it myself when next out.
A few queries —- appreciate any advice
1 - any idea which fuse the motor is linked to - just to double check
2 - best place to source the motor - eBay maybe? Anyone got a link
3 - best way to access the motor - looks like its a font wheel removal first?
Any help appreciated
Mark
I would look for a source after I had seen the motor first...
fuse, I am not really sure, but it is shared, for sure with other equipment, so you would finde more things out of order...
The access I think it involves a wheel and a wheel inner arch, but not absolutely sure...
1..under engine bay fuse box [ 10amp fuse ]
2...yes  [ebay ] berlingo b9   from a tenner..check part number
3...o.s.front. if right hand drive. under wheel arch..full left lock..you might not need to take wheel  off..just bend the inner plastic back
..pump should be there.....
[-] The following 1 user says Thank You to gazthelad for this post:
  • mhjc
Get a decent pump if it’s not the fuse, the cheap ones are junk.
The Febi bilstein ones are same as o.e
[-] The following 2 users say Thank You to Lighty for this post:
  • Art b, mhjc
front hubs
Last Post: jemselectrical
Today 05:01 AM
eBay Diagbox interfaces
Yesterday 10:57 PM
» Replies: 22
2001 MK1 Berlingo seats
Last Post: Joseph_jsms
Yesterday 10:46 PM
Rear back door air gap??
Last Post: Gene1
Yesterday 10:35 PM
Tailgate Insulation
Last Post: Matt Haigh
Yesterday 10:22 PM
front hubs
Last Post: mopedracer
Yesterday 07:08 PM
Mk II 2018 Anniversary Door Sill Clips?
Last Post: Jerry123
Yesterday 04:06 PM
Problème ABS
Last Post: Zion
Yesterday 01:27 PM
Adblue warnings
Last Post: Zion
Yesterday 07:19 AM
BSI
Last Post: Zion
23-09-2023 06:40 PM
