[For Sale] 4x 15" Alloys with tyres
4 MSW alloys with spacers and fitting kit for a B9 Berlingo. (https://www.wheelbasealloys.com/alloy-wh...go/2nd-gen)
205/65 15 tyres. 2 good hankook kinergy eco tyres. Two nexen BlueHD need replacing.
Wheels are 4x108 PCD 6.5J and come with spacers(27mm offset), spigot rings and bolts to suit 2008 to 2018 Citroen Berlingo/Peugeot Partner. Will also fit Citroen C4, Peugeot 308 and 408.
With different spacers, likely to fit pretty much any 4 bolt Citroen or Peugeot. May also fit vauxhall crossland X.  My understanding is the M59 Berlingo is 5.5J and 24mm offset but the same bolt circle.  The wheel bolts are M12x1.25. I've got a full set (16) locking wheel nuts with adapter. Another 4 unused locking nuts and 8 unused non-locking nuts.
A good resource to see if they'll fit yours... https://www.wheel-size.com/size/citroen/berlingo/
Looking for £250. I would prefer pick up from Kendal although I could deliver within the M6/M61 corridor between Kendal and Warrington, around Preston/Blackpool or Skipton/Harrogate/Bradford area.
Could arrange a courier at a push, but that'll cost ~£50.
Attached Files Thumbnail(s)
The Bus II: 2019 XL Flair 1.2
I only seem to be able to post 5 pictures...
So here's the tyres and bolts
And finally...
The spacers with spigot rings and the spec stamped on the inside of one of the wheels.
And Finally Finally Smile
Here's the car with that had the wheels on:
SOLVED: P20F6 fault
Today 08:28 AM
Coolant
Last Post: Martinze
Yesterday 08:24 PM
Leaking windscreen or aerial
15-04-2026 08:50 PM
