[Engine] Berlingo 2.0Hdi 2003 multi wont rev past 2000RPM
Threads: 5
Thanks Received: 2 in 2 posts
Thanks Given: 10
Hi all,
Had the oil and engine light come on yesterday, topped up with oil and the engine doesn't seem to be running on all cylinders, massively lacking power and wont rev past 2000 rpm any ideas on where to start looking ?
Thank in advance!
Threads: 123
Thanks Given: 250
34
19-04-2019, 09:12 AM
(This post was last modified: 19-04-2019, 09:13 AM by cancunia.)
You may/should have an OBD port on your car, it'll be behind the flap under & to the right of the steering wheel, above the BSI/fuses. If so, get an OBD code reader & Torque app, check for error codes and turbo boost.
Threads: 5
Thanks Given: 10
(19-04-2019, 09:12 AM)cancunia Wrote: You may/should have an OBD port on your car, it'll be behind the flap under & to the right of the steering wheel, above the BSI/fuses. If so, get an OBD code reader & Torque app, check for error codes and turbo boost.
Thanks for the reply yes got a port, waiting for the reader from eBay now, was booked in to have it read this morning but car was so under powered I gave up on the trip haha
Threads: 20
Thanks Given: 7
15
(19-04-2019, 06:01 PM)peterbol Wrote: (19-04-2019, 09:12 AM)cancunia Wrote: You may/should have an OBD port on your car, it'll be behind the flap under & to the right of the steering wheel, above the BSI/fuses. If so, get an OBD code reader & Torque app, check for error codes and turbo boost.
I’m going to say fuel pressure sensor. Had a similar experience with the later 1.6hdi engine.
Threads: 5
Thanks Given: 10
(20-04-2019, 05:14 AM)Tree Wrote: (19-04-2019, 06:01 PM)peterbol Wrote: (19-04-2019, 09:12 AM)cancunia Wrote: You may/should have an OBD port on your car, it'll be behind the flap under & to the right of the steering wheel, above the BSI/fuses. If so, get an OBD code reader & Torque app, check for error codes and turbo boost.
Thanks for that Tree, I'll look into testing it while waiting for the reader to turn up!
Threads: 5
Thanks Given: 10
SOLVED: Turned out to be broken wire from ECU to injector No 3, routed 2 new wires sorted it!
The following 1 user says Thank You to peterbol for this post:1 user says Thank You to peterbol for this post
• geoff
Threads: 75
Thanks Given: 223
164
Good find Peter.
Threads: 5
Thanks Given: 10
(14-02-2021, 09:19 AM)Zion Wrote: Good find Peter.
Thanks, completely forgot about this post, so thought I'd update for anyone that may have similiar issues at some point..
Electrics are one of the first avenues to go down with fault finding with these Blingos..wiring's so flimsy on these M59s..
Threads: 67
Thanks Given: 237
50
^^^ Even so it is still good going for a 17 - 18 year old car ..... plenty more life left in the old girl should you choose to keep her alive.
Serieal Berlingo owner
Threads: 5
Thanks Given: 10
(14-02-2021, 03:54 PM)geoff Wrote: ^^^ Even so it is still good going for a 17 - 18 year old car ..... plenty more life left in the old girl should you choose to keep her alive.
Trying to Geoff, versatile little motors blingos !
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
