[Steering & Suspension] Powerflex Front Anti Roll Bar Bushes
Hi.
Here again with one new upgrade.
I m thinking is possible to change the bushes for this performance model.
The noise increase with the time. 2 year after my last change the bushes and I need change again. (20.000 km).
This model of bush maybe fix the famous angry clonk.
https://rover.ebay.com/rover/0/0/0?mpre=...2830806070
Regards.
Sent from my COL-L29 using Tapatalk
Vigo, The cradle of all Berlingos / Partners.  Big Grin Heart
Are you definitely sure it is the bushes making the noise? I went through changing lots of different suspension components and still had the "knock" at the front only to find it was actually the front shock absorbers, they weren't leaking and seemed OK but when I actually took them out of the spring assembly, the piston rods had noticeable wear in the I could move the rods from side to side [as well as the normal in/out movement] and that was actually the cause of my knock.
(23-04-2019, 08:52 PM)NANO_Vigo Wrote:  Hi.
Regards.
Did you do this upgrade ? If so has it cured the dreaded front clonk rattles ?
2010 BERLINGO MULTISPACE XTR
Regards.
Yes I did 4 month ago, and the change was amazing. Now driving better than new.
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
