[Warning Light] Engine management light
Hi all, I have a 2005 Multispace 1.9 diesel. when I go up hill and revs drop below 2000, if I do not change down quick enough the warning light comes on, nothing else happens and it drives as normal. The light goes out after starting the engine a couple of times. I have taken it to a couple of garages for a diagnostic check but nothing conclusive shows up. Any ideas ?
Oil pressure?
Is the oil level at the high mark? do not trust the digital dash readout if you have one.
For what it is worth. I have a Multispace xtr 2013 reg. My engine light came on the motorway miles away from home. I was going on a weeks hiking trip. I called my breakdown firm and when he switched on the light was not there. He fitted the diagnostic kit he had which showed nothing. He said there was Citroen garage nearby and I should get it checked out in the morning, my car can be used as micro camper.
Citroen looked at it and found nothing but said there could be an issue with some small part which I forget the name of, sorry; and to get it checked at my home Citroen dealer- which I did. I got the impression it was known issue and something was replaced. both the breakdown man and Citroen dealer both said if it happens again, switch off, wait five minutes and restart- something about the computer system rebooting correctly.
Thanks guys for the replies, you have given me some food for thought.
Next gen Berlingo coming 2030
Last Post: shedpete
Today 08:36 AM
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
