75BHP timing kit
In need of some help please..
I have a 2015 (65 plate)75BPH Berlingo Enterprise, Hoping to order timing kit on Eurocarparts with the current half price offer running out today..
Three different belt kits show up for it two with 25.4 width one at 25mm.
Middle of my Vin is 7B9HNO.
Can the engine code for belt be derived from this or must I find another code in the engine bay somewhere?
I've read through some posts on this but I'm still none the wiser
Tom
My Vehicles: 2015 Berlingo Enterprise Van 75 1.6Hdi
                   2021 Nissan Qashqui 1.5DCi
The best places to look for part numbers are catcar.info & service.citroen.com then use the numbers for a cross reference search. The Citroen website is best, but you need to register so takes a bit more faff to use.
You can also look on GSF where there's a regular 60% off (code is VIP60 this week).
  • tomhick024
(30-04-2019, 09:38 AM)cancunia Wrote:  The best places to look for part numbers are catcar.info & service.citroen.com then use the numbers for a cross reference search. The Citroen website is best, but you need to register so takes a bit more faff to use.
had been looking on catcar.info. They had listing for 9HN bot not for 9HNO.. ill have a look on the citreon one..
Thanks for the info
had been looking on catcar.info. They had listing for 9HN but not for 9HNO.. ill have a look on the citreon one..
Thanks for the info
Looks like your 2015 model year is some kind of crossover so that's why you can see 2 options. You could also try the Febi website, they work on reg number but may still give 2 options..
https://partsfinder.bilsteingroup.com/en...iming+belt
  • tomhick024
Got my engine code and phoned local eurocarparts/Team PR Reilly and a very helpful dude gave me the timing kit number required. Happy Days
Thanks for your help folks
Can you please post the kit number for anyone else with the same engine who may require a kit either now or in the future, thanks.
  • tomhick024
There seems to be a few variations of engine/code in 2015..My engine is a DV6ETED4
The timing kit P/N is 348540158
The last digit (8) does not matter as that is a number that each different manufacturer uses so they will vary
HTH
[-] The following 1 user says Thank You to tomhick024 for this post:
  • geoff
Thanks Tom .........................
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
