1.6HDi turbo slightly blowing oil
Hi all,
I suspect that my turbo is slightly blowing oil into the compressor side of the turbo, towards the intercooler (1.6HDi; 90bph; 2007; M59; no dpf/fap; ~93,000k miles; DV6ATED4; 9HXC engine).
There has always been a little bit of oil in the air intake (pre-turbo) and comparing to photos of other people, it seemed normal. I would not have noticed, but I installed an oil catch can and all the air intake pipes are clean. I took the air intake pipes yesterday and there is a bit of oil sprayed in the air intake pipe, just before the turbo. Crucially, only there, like the turbo when spinning has sprayed a bit of oil. The rest of the pipes are spotless, from the oil catch can to air intake, no oil whatsoever.
I took the rubber connection (from turbo to intercooler) just connecting to the input for the intercooler and there are a few drops of oil there. I had cleaned the intercooler before (~2 weeks ago) and cleaned that one, so I know it is new oil.
The car does not consume oil in between oil changes, so not really that much of a problem, but still.
AFAIK, there are several reasons why the turbo would blow oil pass the rubber o-ring (compressor side of turbo). Not in order of significance or likelihood to have happened.
1. Oil return pipe (the big fat rubber tube under the turbo) is somewhat blocked or kinked.
Thus, the turbo cartridge gets compressed with oil, but slow to return, hence an increased pressure and leakage. Does not seem like it. I have not removed it to check, but there is no kink in the hose. It is pretty fat pipe, so unlikely to get blocked. It is a stock turbo + pipe, so unlikely that it has been previously rebuilt and RTV silicone put on the return seal to block the exit.
2. Knackered turbo cartridge.
I already checked the play in the turbo shaft and it is pretty normal. On cold turbo there is a minimal play (radial; left-right, up-down) and no axial play (in-out). On warm engine/turbo, there is no play whatsoever, so the shaft gets sealed pretty good with the oil. So, cartridge is likely to be in a fairly good state.
3. Overfilling of oil.
The return turbo oil feed pipe cannot quite return oil fast enough resulting in an increased pressure. I ruled that one out, as the oil is ~3/4 full, i.e. 3 bars below max on dipstick.
4. Increased crankcase pressure, e.g. blow-by.
So, crankcase is under excessive pressure and oil gets returned to the turbo return pipe or cannot return oil as easily and results in an increased pressure in the turbo cartridge. AFAIK, this is probably more of a cause for ball-bearing turbos.
That is difficult to rule out. I already asked if anyone knew the reference values for the crankcase pressure of a new engine. Unfortunately, nobody seems to know. Saw somewhere that it has to be <50mbar. I measured mine and it is ~1.37mbar, so pretty minimal. I measured this before and after oil catch can, not really any measurable difference. I might have to fit a probe on the oil filler cap and measure long-term under load for a week.
The PCV or more correctly CCV (CrankCase Ventilation) valve can be blocked and hence increasing the crankcase pressure. I have already replaced the membrane and since there is a minimal crankcase pressure, that is unlikely to be the cause. Let's say the oil filler cap does not get blown out when opened and the flow of air from oil filler cap is pretty insignificant.
5. All turbos might blow some oil on the compressor side.
I doubt that. A turbo should not do that, otherwise you get oil in the intercooler and reduced air cooling efficiency.
6. Age + compressor side o-ring.
My car is ~92,000k miles, so the rubber o-ring (compressor side) might have perished a bit and hence passing some oil under pressure. That is possible. I have a slight blue-ish smoke on startup and I thought it might be valve stem seals, but it is possible that the oil gets pooled in the intercooler and/or other places and gets blown in on cold startup. Once the turbo gets hot the seals compress better and the smoking stops. If the compressor side o-ring was somewhat past its best, then it should smoke blue under load, not just on startup. There is no blue smoke under load.
So, are there any other possible causes?
The way I see it, it is probably N:6. I can potentially get a rebuild kit with o-rings and rebuild the turbo or I can get a new cartridge and again rebuild the turbo. Both do not seem too expensive from reputable sources, not the cheap Chinese versions.
Any ideas are more than welcome and apologies for the long post.
Cheers,
saskak
If you're using little or no oil between changes, I'd say it's probably ok & to just keep an eye on the oil in the pipes & the boost pressure? It's probably a combination of age & oil pressure. Maybe try some heavier 5w/40 on the next change.
I remembered this post (#31) as a recommended cartridge if you want to get a new one, but I'm sure there are others.
https://www.berlingoforum.com/thread-178...#pid113881
  • saskak
(01-05-2019, 01:25 PM)cancunia Wrote:  If you're using little or no oil between changes, I'd say it's probably ok & to just keep an eye on the oil in the pipes & the boost pressure? It's probably a combination of age & oil pressure. Maybe try some heavier 5w/40 on the next change.
Yeah, I should try the 5w40. It will probably help with the oil passing through seals (valve stem and turbo o-ring). I was thinking of going to a UK company as I can phone them and check the numbers for the Chra cartridge.
Good call on the boost pressure. I have not checked it, but will get my torque app to see what the values are.
A quick afterthought.
AFAIK my engine is one of the last of the DV6ATED4 (Sept 2007 or last of the M59s) before being superseded by the B9, so I suspect (not checked) that the lower turbo oil feed pipe banjo bolt filter (what a mouthful) is not present. Maybe wrong, but I thought that Citroen/Peugeot redesigned this and/or there was a memo to the dealership to remove these or at least replace them with not so fine mesh/filter.
Would a turbo oil feed pipe without a banjo bolt filter increase the oil pressure in the turbo cartridge? I would have thought so, unless within tolerances of the seals or oil return pipe flow capacity. Less restriction (no banjo bolt filter) will inevitably increase the flow and pressure of the oil and of course subsequently increased oil pressure in the cartridge itself. This coupled with aging rubber compressor o-ring might have led to the turbo blowing a bit of oil?
My M59 is 2008 and did have the banjo filter until I took it out. The filter wire mesh is not very fine and looks to be intended to stop larger (compared to the oil filter) bits of crud. It's a strange place to have that wire filter as it's just after the main oil filter AFAIK.
I think Citroen put a revised & longer mesh filter into later engines, but depending on what service bulletin you read, it's optional to remove the banjo filter or put the revised one in.
As far as oil pressure is concerned, a clean wire mesh filter should make little difference.
  • saskak
All turbos pass a bit of oil, its when you are blowing excessive blue smoke out and using oil its time to worry. If its using only a small amount of oil you have not got a problem, you will find oil where you are looking.
The banjo bolt is not a problem if the vehicle is serviced correctly, more on the road with the filter still in place than not, that includes mine and a few old customers of mine.
Time to stop worrying to be honest - it sound like everything is fine.
  • saskak
(01-05-2019, 05:16 PM)polar Wrote:  All turbos pass a bit of oil, its when you are blowing excessive blue smoke out and using oil its time to worry. If its using only a small amount of oil you have not got a problem, you will find oil where you are looking.
Have I not put an oil catch can with clean pipes I would not have noticed.
[-] The following 1 user says Thank You to saskak for this post:
  • polar
I agree with polar, you're worrying the car to death.
  • polar
(01-05-2019, 05:56 PM)jj9 Wrote:  I agree with polar, you're worrying the car to death.
I have not really worried too much about it. It was an observation and wanted to know if that is the general state of play. IMHO, pretty stupid seals/design if it blows oil on the compressor side.
I'll rephrase it then, meddling the car to death.  Big Grin
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
