  • 1 Vote(s) - 2 Average
Read shock absorber
.jpg   20190406_065710_Richtone(HDR).jpg (Size: 1.76 MB / Downloads: 27)
.jpg   20190406_065710_Richtone(HDR).jpg (Size: 1.76 MB / Downloads: 27) Hello all I've put some bigger Wheels on my 52 plate berlingo. Now going over speed bumps with two people in the back the wheels run on the rest arches!. Is there any shock absorbers out there that I can use which are stiffer than the original ones??
Shock absorbers ( dampers ) don't control ride height so don't buy any of them for goodness sake it will be a waste of money as they won't fix your problem in the slightest.
The suspension springs control ride height but in a Berlingo are in the form of torsion springs so cannot be easily altered. From my understanding you can replace the spring with a stronger one, I'm sure others will advise in more detail but it will be a big and possibly an expensive job.
Can you get some longer bump stops ?
He'd have less suspension travel and will bottom out earlier
Today 01:49 PM
Yesterday 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
