electrical
can any one please help .
the drivers side window will go down with switch but will not go up ,motor works when connected direct to 12v supply, when testing switch poweris shown on both sides when switched in both directions , the two wires at motor show power when window is put down but when trying ton put upboth wires are dead, iwas wondering if a relay is not working or is there a break in wire, it would be helpful if i could get a wiring diagram for the electric windows
 thanks for now
(04-05-2019, 05:58 PM)mickrochip Wrote:  can any one please help .
 thanks for now
Does the passenger side work ok?
There's sometimes an extra electrical part on the driver's side to make the 'one touch' function work. Diagrams attached, hopefully one will match yours.
.pdf   Window(1).pdf (Size: 806.4 KB / Downloads: 21)
.pdf   Window(2).pdf (Size: 1.23 MB / Downloads: 16)
thank you very much for your quick reply,
yes passenger side window is working perfectly,
i even changed switches around to check if it was switch.
when button pressed for up or down i hear a click in fuse box  but window still wont go up
Mine is similar, the driver's side often won't work when it's cold outside but the passenger side is fine. I think it's that extra component located somewhere near or on the BSI. It should be possible to bypass it.
Please post a reply on how you get on?
thanks for info.,
 do you mean the window relay or the electric window module,
and canou tell me if they are under dash deside fuse box or in engine bay
I think it's item 6030 on both diagrams that you need to find, if you then scroll down to the 3rd page you can see that on window(1) it's in box B above the clutch pedal & in window(2) it's in box C somewhere in the region of the BSI.
thank you for your  info
i have not got round to locating thi unit
by the way is it called an electric windows ecu.
my local breaker says this item is not available , so will hove to go to citroen fot it , i expect it will be costly
 i will let you know in due course
I'm surprised that a breaker says it's unavailable as it's a standard feature AFAIK. From looking at the wiring, it should be possible to bypass so that the driver's window operates in the same way as the passenger's window. In any case, it would be good to know how you get on.
Have a look on ebay there are quite a few on there.
  • cancunia
(08-05-2019, 06:44 AM)Tomcat3 Wrote:  Have a look on ebay there are quite a few on there.
Indeed there are, thanks for the tip (9623272980). A green box by the looks of things, should be reasonably easy to find & maybe even fixable.
Today 03:10 PM
Yesterday 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
Last Post: stu76
18-08-2026 07:16 PM
