what part number is this turbo pipe bolt
Hi all,
I could not find what is the part number or description of this particular bolt (numbered 2 in the picture, the left one).
The head-rounded bolt clips the turbo pipe that goes in the intercooler. It also screws the upper heatshield in place.
Any help is more than appreciated.
Cheers,
Saskak
I think this is it....
From Catcar it's part number 1436a9 item 16
https://www.catcar.info/citroen/?lang=en...aWVyPT0%3D
Glovebox direct item 6
https://gloveboxdirect.com/1436a9/p0/
IIRC, there are some more of these on the air intake?
  • saskak
(07-05-2019, 09:50 AM)cancunia Wrote:  I think this is it....
Cancunia, you are a star! Thank you very much indeed. I could not really figure what the part number is. Many thanks again.
Cheers,
Saskak
I should have checked servicebox. The part number is there as well, not too sure what I was looking....
I discovered that the same bolt on my engine was loose today. It needed about 1 1/2 turns to tighten.
  • saskak
(22-05-2019, 04:41 PM)cancunia Wrote:  I discovered that the same bolt on my engine was loose today. It needed about 1 1/2 turns to tighten.
I did the opposite, I sheared the bolt in my attempt to tighten it "properly". That is why I asked about the part number. Managed to unscrew it and replace it with a new one. This time I did not tighten it that much.
Thanks for the observation, will monitor it.
Yes, easily done with the M6 thread. It may be hold better with a spring washer or thread lock.
Last Post: JPCoetzee
Today 03:52 PM
OIL Drip
Today 01:49 PM
Today 01:42 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
Potential Purchase!
09-03-2026 03:03 PM
