  • 25 Vote(s) - 2.56 Average
[Engine] 2.0 hdi turbo fault
Hi guys
new to posting on the forum but have found it very helpful looking up all the little niggles on my 2003 2.0 hdi berlingo workhorse. I have what sounds like an air leak to, or from the turbo, when you go over 2000rpm it spools up ok and can hear it, but there is no boost. Had a look from under the van this morning, is it possible there could be a crack in the plastic pipe between turbo and inlet ? any advice please
thanks Chris
It more likely that the boost pipe has just come loose. The boost pile is quite hard and unlikely to just crack. There only held on with a soft silicone joiner and a couple of crappy clamps. ( there 60 mm if you replace with jubilee clamp)
(06-12-2011, 11:04 PM)duamoHDI Wrote:  It more likely that the boost pipe has just come loose. The boost pile is quite hard and unlikely to just crack. There only held on with a soft silicone joiner and a couple of crappy clamps. ( there 60 mm if you replace with jubilee clamp)
hi pal. my 1.6HDi berlingo makes a similar noise. has its just started to do this? mine has always had the noise from new. also im sure that on the 1.6 HDi the turbo is allways being used. its just works along side the engine from low to high Revs to assist the engine.
1.6 HDi Berlingo van , 2011 plate
hi
thanks for your response, there is definateley a leak or valve stuck open somewhere. No fault lights on dash or black smoke from the exhaust, it just happened suddenly as i was pulling onto the M25. Drove to work today, and it is way down on power, stopped at my local citroen dealer to check availability of the hoses both of which they say are on back order !!
as suspected duamo hdi, removed boost pipe and silicone top pipe has a small hole in it, nice one, will patch it up till citroen send me a new one
Side Light Bulb Holder
Yesterday 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
