Threads: 121
Thanks Given: 248
34
I'm changing my gearbox oil and can't decide how much to put in there. My driveway is on a slope so it's very tricky to get the car level in both directions in order to use the filler plug level.
I've read in Haynes and on here in a couple of places that it's 2.0 Litres, but the Citroen Engine Service Data that I've been reading says 1.8L Will there be an issue if I put 2.0L in?
Threads: 20
Thanks Given: 2,126
18
2 litres is what I've put in mine.
Strawberry flavoured windows
Thanks Received: 531 in 479 posts
Thanks Given: 188
23
13-05-2019, 07:44 PM
(This post was last modified: 13-05-2019, 08:03 PM by Tomcat3.)
I know this don't help you with a 1.6hdi as ive got a 1.4 petrol but with my spec gearbox it was 2 litres and that was how much drained out. So Haynes was spot on for once. Make sure you use the correct spec oil it makes all the difference.
Are we there yet?????
Threads: 29
Thanks Received: 3 in 2 posts
Thanks Given: 58
How often should the oil be changed ? Is it really necessary?
