Hi all,
I had a rattling rear heat shield , the one between the engine bay and the catalytic muffler/converter (no catalytic converter on my car). In case anyone is interested in replacing these here is a video of how I did it: https://www.youtube.com/watch?v=NyL5nRiFfT0
My main problem was taking the front-heat shield out, impossible on my 1.6HDi (Peugeot Partner; M59; 90bhp; 9HXC engine), the turbo actuator arm and the turbo oil inlet pipe were in the way. I unscrewed every bolt on the heat shields and the two exhaust brackets and the catalytic muffler dropped underneath the car. From then on it is a straightforward replacement, although had to take the front heat shield out. The noise was rather embarrassing when idling, like the engine was about to drop off, now it is quiet.
Rear heat shield replacement part number: 1723EY
Cheers,
saskak
Cheers,
saskak
