Partner 1.9D overhearing idle
Hi I still have my issue with overheating in traffic when I get up to speed the air cools it back down so I’ll start with what I’ve changed to help.
New radiator
New relays
New fan
New coolant
I’ve read something about the fuses I’ve checked the fuse box in the engine bay but heard something about another fuse box underneath that one?
Anyone any ideas what could be left
I don’t have a multi meter or faulty code reader to use
So the cooling fan is not cutting in?
(19-05-2019, 08:33 PM)polar Wrote:  So the cooling fan is not cutting in?
No, changed the fan also
So you need a multimeter to test for power but have you changed the fan sensor yet?
I cant remember where it is on the 1.9 it could be in the rad or the thermostat housing.
Until you can get to do something you could wire up a switched wire so you can turn the fan on manually, if it keeps getting hot you could damage the head gasket, crack the head or crack a liner.
(20-05-2019, 06:46 AM)polar Wrote:  So you need a multimeter to test for power but have you changed the fan sensor yet?
It’s due it’s MOT next week so might just throw in the towel and get them to do it and get the mot done at the same time
Mileage
Today 04:33 PM
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
