Wanted to make you aware of a slightly significant addition to interaction between users on the forum.
You now have the ability to Tag Users when writing your response. All you need to do in order to tag someone is the following:
For example:
Will produce:
@[Chris] has had an issue with his spare tyre too.
This will then alert him via PM that he has been tagged.
It is a great way of getting someones attention who you want to see a particular thread because they may know about the topic, or you think they may be interested.
As always, a detailed run down is available in the Help Documents, where you can also learn how to opt out of being tagged. Click here for all that info.
Code:
@[usernamehere]For example:
Code:
@[Chris] has had an issue with his spare tyre too.Will produce:
