Shelf in rear Berlingo window
I like the look of Amdros rear window storage unit but the price is considerable and I need to use that window when reversing; before seeing that I had thought about organising a shelf to give a flat area in the rear windows to put the odd thing on when cooking or making a drink; not for use in transit. Has anyone made such a thing already.
[-] The following 1 user says Thank You to lakeside for this post:
  • Little boy blue
hi there, I just stumbled over your post, have you found a solution since? I am at the same stage as you were a year ago and I hope you'll see this :-)
I think I have made what you are talking about. Not sure why you need to use the window to reverse. Mine hasn't effected reversing at all. Got mirrors for that  Smile
[Image: IMG-20180926-172902.jpg]
[Image: IMG-20181002-155244.jpg]
Adam
[-] The following 1 user says Thank You to thestig84 for this post:
  • H2Sparks
(23-05-2019, 02:32 PM)lakeside Wrote:  I like the look of Amdros rear window storage unit but the price is considerable and I need to use that window when reversing; before seeing that I had thought about organising a shelf to give a flat area in the rear windows to put the odd thing on when cooking or making a drink; not for use in transit. Has anyone made such a thing already.
Do you mean something like this?  Took me a few minutes to knock up - next version will lock into the parcel shelf slot.  Super simple; super useful.
Attached Files Thumbnail(s)
I eventually made a shelf using a lightweight plastic packing sheet screwed to the side of the car. When I am able to travel I am going to see how much, and for what, evolves using it.
I recall needing to put bits somewhere other than on the bed/floor or elsewhere it could be covered up, or knocked over.
(19-07-2020, 08:04 PM)thestig84 Wrote:  Creo que he hecho lo que dices. No estoy seguro de por qué necesita usar la ventana para invertir. El mío no ha efectuado la marcha atrás en absoluto. Tengo espejos para ese  AdamSmile
Hola. También me gusta mucho el vestuario de Andros pero es demasiado caro para mí y no lo envían a España.
¿Tienes la plantilla y las medidas de los muebles que has hecho?
Te estaría muy muy agradecido ¿Puedes compartirlo?
The pics look good, but please use Google Translate.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
Hi,
Does this just rest on the parcel shelf slot or is it held in by the window holding a flap in place?
Sent from my iPad using Tapatalk
Eventually I made a shelf using a 15cm wide piece of lightweight plastic packing sheet screwed to the side of the car either side of the existing window shelf. It is just handy to have somewhere to put odd things; other than on the bed, floor or elsewhere where it could be covered up, or knocked over. I have a makeshift plastic tube and rubber squeeze bulb acting as a tap which I store in one side shelf when it is not in use. Other than the tube set up I only keep soft things in it to avoid rattling.
Off topic. I use the tap/bulb for washing over a little metal bowl that I have, or in a washing up bowl. When the tube is in a water bottle I can squeeze the bulb to raise water. I either hang it from near the roof and press with one hand; or place it on the floor and press the bulb with one foot, - the tubing is long enough to reach the floor and the bulb is located somewhere to suit along the pipe.
I can use this water system outside by taking the whole lot out. It works well saves tipping water often from a bottle to rinse, add water etc. I recall I saw this idea on a campervan set up on Youtube.
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
