Suspension
Huh can anyone help me. Im looking to adjust the height of which my van is off the ground. Im looking to higher it. Does anyone know if this is possible?
You could add spring helpers which are a bit of a half arsed measure, but would work, used to be used for towing a lot to help the springs, buy the right size for your springs and they are basically a rubber spacer fitted between a coil or two that effectively reduces the springs ability to compress and will definitely raise the height a little bit ??
I have also considered 307 coil overs as a possible front end solution, they look similar, but I can’t say if they 100% fit as I’ve not tried it as an exact fit
(23-05-2019, 10:37 PM)dumdum Wrote:  You could add spring helpers which are a bit of a half arsed measure, but would work, used to be used for towing a lot to help the springs, buy the right size for your springs and they are basically a rubber spacer fitted between a coil or two that effectively reduces the springs ability to compress and will definitely raise the height a little bit ??
Thanks. Looking to raise it about an inch or 2
An inch or two may be pushing it without longer dampers and new springs... your getting towards the dampers topping out being very honest, and probably not safe as the wheel will then not track the bumps and hollows causing traction issues
Yet another ABS fault
Today 10:56 AM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
